gary68plyfury
Hey All, this is my first post here. Hopefully I do it correctly.
I have 68 Plymouth Fury III with a 2barrell 383 that I bought 2 weeks ago, non-running and a good number parts taken off. The part I'm concerned with is the carb.
It looks to have 2 cork gaskets between it and the intake manifold and the gaskets are holding the choke open. The choke can't move until I removed the ( I don't know the correct name) choke rod that goes in to the manifold. Once I disconnect the choke rod, I can more the rod down and manually close the choke.
Should I remove the 2 cork gaskets and install one thin one for the choke opens and closes? I've heard/read the cork gaskets are used as insulators and help stop vapor locks.
Currently I don't have the fan belt pulley to drive the water pump, so I only run it for about 5 seconds. Could probably go longer. Also don't have a fan. And don't have some interior parts, but one issue at a time.
Thanks,
Gary
Thanks,
Gary
