Dodgy Dick
What is biggest capacity small block or stroker kit options, your comments/recommendations etc, welcome.
Dodgy Dick small block big block is cheby speak,383 is an intermediate like a Ford 390-it's about the spacing between the cyl. bore'sWhat is biggest capacity small block or stroker kit options, your comments/recommendations etc, welcome.
Huh?Dodgy Dick small block big block is cheby speak,383 is an intermediate like a Ford 390-it's about the spacing between the cyl. bore's
Being that his car is a pillared four door sedan it would have originally come out with a 318 2bbl when new there. All the pillarless four doors came with 383 2bbl engines.What's in your Dodge now? From the title of the thread I am guessing a 383. If you read Commando's assignment you should have your questions answered.
Also referred to as a "door stop", or a "boat anchor".The stroker 383 you are hearing about normally refers to a Chevy stroked 350 small block.
Q&A period on stroking tomorrow.
Any period correct V8 engine with 727 will bolt right in other than the Hemi 426.Thanks Commando1, Sure is confusing there are so many options and conflicting info but your posted article helps. Perhaps I should ask what larger capacity engine bolts straight in where 318 w/- 727 currently sits ?
Using the 318's trans., a 340. You could use a 360, but I think you would have to change the torque converter.I am asking what is biggest capacity small block engine/s that will bolt straight into my 69 Fury AKA Aussie Dodge to replace 318 with 727 auto?
There are bolt-in Small Block crate engines commonly available that are 400+ cu. in.I am asking what is biggest capacity small block engine/s that will bolt straight into my 69 Fury AKA Aussie Dodge to replace 318 with 727 auto?
