1. HANK 440 UNLIMITED
    HANK 440 UNLIMITED New Member
    33
    5
    Jun 14, 2020
    Montréal PQ
    Hi guy's
    I want to install a 440 in my Polar instead of my 318, do I have to have a Schumaker motor mount kit or did it fit directly ? thank for your help
  2. Davea Lux
    7,155
    1915
    Mar 27, 2017
    Cornelius Or
    Motor mounts for 440 are a direct bolt in. The 318 transmission will not bolt to a 440. Drive line will have the small u-joints and check the rear end to be sure it is an 8.75 unit, 8.25 can not take 440 torque. Radiator is also different as are all the accessory mounts and pulleys.
    • Like Like x 2
  3. HANK 440 UNLIMITED
    33
    5
    Jun 14, 2020
    Montréal PQ
    Thank you very much Dave for the information, I bought a complete mechanic of a 72 New Yorker from the radiator to the drive shaft with the complete electrical harness ,but I discovered today that the radiator that I have in hand is not the right model, I need that number 3574656 and this radiator is a 26" and my rad support is made for a 22" maximum ?
  4. Davea Lux
    7,155
    1915
    Mar 27, 2017
    Cornelius Or
    318 engine would have a 22" radiator unless the car was ordered with the maximum cooling option which came with the 26" radiator. You can probably find a replacement core support at a wrecking yard that will accommodate the bigger radiator. 22" from a 318 has the inlet and outlet on the wrong sides to use with a 440 and would be too small in any case. Most of the 383/440 cars had 26" radiators and the core support should not be too hard to find.
    • Like Like x 1
    • Agree Agree x 1
  5. HANK 440 UNLIMITED
    33
    5
    Jun 14, 2020
    Montréal PQ
    OK but the radiator support must surely be different from model to another ?, where they are the same and if so then maybe I could take that of a Newport 73 that there is at the junk yard ?
  6. 1966newport
    1966newport Well-Known Member
    585
    38
    Jan 20, 2012
    my 66 newport and 68 300 both have a 440 and 22 inch radiator, no issues.
    • Like Like x 1
  7. HANK 440 UNLIMITED
    33
    5
    Jun 14, 2020
    Montréal PQ
    yes that I understand, even that the New Yorker 72 that I took the mechanic also had the 22" but the taxis and the police had 26" and project is to make a police car i want to do it as exact as possible
  8. Davea Lux
    7,155
    1915
    Mar 27, 2017
    Cornelius Or
    70-71 Plymouth, Dodge and Chrysler use the same core support for 26" radiator. Most police, taxi, and A/C equipped 383/440 cars will have the 26" radiator.
    • Like Like x 1
  9. HANK 440 UNLIMITED
    33
    5
    Jun 14, 2020
    Montréal PQ
    what is your opinion on 72 or 73?
  10. Wollfen
    Wollfen Old Man with a Hat
    6,674
    3423
    Jul 18, 2012
    Greenville NC
    72 to 73 is the same also, but the 1970 Plymouth core support is not, it wont fit.
    • Like Like x 1
  11. HANK 440 UNLIMITED
    33
    5
    Jun 14, 2020
    Montréal PQ
    OK then only Dodge not Plymouth and what about Chrysler ?
  12. Wollfen
    6,674
    3423
    Jul 18, 2012
    Greenville NC
    Chrysler is fine yes, no probs there.
    • Like Like x 1
  13. HANK 440 UNLIMITED
    33
    5
    Jun 14, 2020
    Montréal PQ
    thank you!
