346 vs 516 heads on 72 400
  1. TroyCo
    TroyCo Member
    115
    69
    Feb 3, 2021
    Oshawa, Ontario
    So here's the drill: I need to rebuild the 346 heads on the 400 in my Polara, and I have access to a set of 516 heads I can put on the engine as well. I have also added a Performer RPM intake, Holley 600 cfm carb, and a comp 262 lift cam recently. I understand the 516s are closed chamber and I would get a slight compression bump with those heads, but are they worth adding to this engine, or should I stay with the originals?
  2. Davea Lux
    8,609
    2081
    Mar 27, 2017
    Cornelius Or
    The 516 heads do give a boost in compression and have a better quench factor.. Downside is that these heads were designed for an era where leaded fuels were the norm. For any type of a performance build, the non-hardened seats in the 516's will erode and the valves will start to sink. You would want to install hardened seats and bronze valve guides as part of any rebuild of those heads. The 346 heads come with hardened seats, so you are ahead of the game in that respect. You might want to consider doing a bowl job on the 346 heads and investing in a set of headers. The downfall of the 400 engine is a low compression ratio to start with, so to get decent performance, you need to get the compression ratio up to about 9.5-1, that will mean a set of aftermarket pistons as part of an engine rebuild. The 400 had a factory compression ratio of 8.2-1 but a lot of those engines ran more in the neighborhood of 7.8-1 to 8.0-1 because of variations in machining. Running modern composite head gaskets is only going to get you to about 8.2-1 to 8.5-1 with the 516 head and that is still well below an optimum performance number.
    • Like Like x 1
    • Thanks! Thanks! x 1
  3. TroyCo
    TroyCo Member
    115
    69
    Feb 3, 2021
    Oshawa, Ontario
    Thanks for the reply. A little more background, I'm just looking to wake it up a little bit, around 300 or so hp. I plan to do a rebuild soon, next year or two perhaps. The 516s I'm looking at have been redone, so those mods are more than likely done to it. The 346s need to be gone through, couple of jacked threads and a broken manifold stud. I'm thinking the cost to re-do those heads will end up close to the cost of the 516s. Whichever head I choose will get the same gasket matching accordingly.
  4. detmatt
    detmatt Old Man with a Hat FCBO Gold Member
    26,203
    12372
    Nov 14, 2010
    The 516’s have bigger exhaust valves installed when they were redone?
    I’d use the 516’s personally and put 1.74 exhaust valves in them.
    • Like Like x 1
    • Agree Agree x 1
  5. TroyCo
    TroyCo Member
    115
    69
    Feb 3, 2021
    Oshawa, Ontario
    Just spoke to the owner of those heads, the valves are stock size, but they had a 3 angle job done, bronze guides and hardened seats installed. For what I'm looking to get out of this engine, it isn't a factor for me to install larger valves at this time.
  6. CBODY67
    CBODY67 Old Man with a Hat
    6,517
    1496
    Mar 27, 2011
    DO consider getting the Mopar Performance porting templates and using them on either set of heads. The smaller 1.60 valves can be somewhat compensated for with a bit longer exhaust duration on the cam.
  7. furious70
    furious70 Senior Member
    1,244
    519
    Aug 18, 2018
    Chitown
    The pros and cons of each for that engine are a wash probably. Go with the most cost effective one
    • Agree Agree x 1
  8. Mike66Chryslers
    Mike66Chryslers Senior Member
    1,138
    669
    Apr 28, 2012
    Ontario, Canada
    Depends what performance level the OP is going for. Ported heads have better top-end power (high RPM) but you sacrifice power at the bottom-end of the power band. Larger ports means the air is travelling slower so you lose the scavenging effect. 516 heads don't have a good port shape vs the later heads to begin with, so probably not worth the effort of porting because you don't gain that much from what I've read.
    • Like Like x 1
  9. CBODY67
    6,517
    1496
    Mar 27, 2011
    Granted, "size" is not everything in head ports, but "shape" can be more important. BTAIM
    I suspect that in the heads orginally designed in the 1950s, that much was done "by sight" and how they looked and were suspected to perform. Getting the right balance of low-lift flow vs high-lift flow was not a real consideration, I suspect, as it came to be in more current times. It was more about total flow and .500" lift, it seemed. Huge valves were supposed to be better. Just "fill or empty the chamber" seemed to be the main orientation. But some began to notice less lower-rpm power with huge ports, which then generated the need for lower rear axle gears to reap the benefits of those huge ports.
    The dynamics of the incoming air into the cyl was not a real consideration, just get it in. Similar on the exhaust side, I suspect. MANY theories of valve sizing had not been fully researched or computer-modeled. And THEN how that all related to rod length-to-stroke ratios, too! Which also relates to "piston dwell time at TDC".
    Generally, even for a hp motor, intake gasket port matching, with casting clean-up in the ports, and possibly some work in the bowl area is good enough, by observation. Past that, LOTS of theories out there of what might work best, by observation.
  10. furious70
    1,244
    519
    Aug 18, 2018
    Chitown
    Go to the moparts tech archives to read what Dwayne tested 10-15yrs ago with these heads. He goes by fast68plymouth there.
    • Thanks! Thanks! x 2
  11. MONC440
    MONC440 Member
    63
    176
    Apr 7, 2021
    Michigan
    If you truly plan on a full rebuild in a few years use the 516 heads and a shim head gasket that will give you a good increase in compression. I have done this many times on mid to late 440 motorhome engines and had great results.
    I have also had 346 heads milled down to a closed chamber and had good results also. Just don't use a composite head gasket because you will loose any benefit you made by going close chamber. The shim is .020 and composites are 0.039 to 0.042. The only drawback to the shim is you need to retorque the head bolts.
  12. TroyCo
    TroyCo Member
    115
    69
    Feb 3, 2021
    Oshawa, Ontario
    How long after installation would that need to be done? Also, can you recommend a decent set?
  13. furious70
    1,244
    519
    Aug 18, 2018
    Chitown
    I used shims on my turbo engine for 8 years and never retorqued.
    Which ones? In today's shortage world, any ones you can get!
  14. Gerald Morris
    Gerald Morris Senior Member
    1,639
    387
    Mar 9, 2016
    Tucson
    This thread WOULD HAVE BEEN very interesting to me, as I have 516, 915, 906 and 452 heads and a 400 I wished to rebuild, BUT A SOCIOPATH BITCH DESTROYED MATHILDA MONDAY MORNING, so I'm a bit at a loss for enthusiasm for this topic, interesting as it otherwise would be to me. I'm facing serious repairs, IFF I can make her damned insurance pay!
  15. MONC440
    MONC440 Member
    63
    176
    Apr 7, 2021
    Michigan
    CHRYSLER 7.2L/440 Mopar big block RB Head Gaskets - Shim steel Gasket Material Parts & Accessories | Summit Racing
    Good ol’ Mr Gasket from summit.
    BTW I always paint mine with spray on copper gasket maker.
    Permatex 80697 Permatex Copper Spray-A-Gasket Sealer | Summit Racing
    Also head bolt re torque is recommended but not required after 500 miles. The last 440 I built was 10.5:1 compression and now has close to 10,000 miles on it and the guy has never retorqued them.
  16. furious70
    1,244
    519
    Aug 18, 2018
    Chitown
    Also, the MP templates, correctly followed will not increase the port size too much for anyone. 440's should have all had max wedge sized heads from the factory :thumbsup:
