383 stock rocker shaft assembly question
  1. ofb383
    ofb383 Member
    51
    14
    Nov 28, 2019
    UK
    Firstly, I hope you've all had a nice Christmas :thumbsup:
    My question to you, should the pressed out stock steel rockers be a nice snug fit to the shaft, maybe a few thou clearance or so ?
    I know all the aftermarket stuff is either bushed or needle bearing, so I guess the stock set up is similar in intention to have a smooth rocking motion but no real play ?
    I've looked though the manual I have but not seeing any spec for ware or serviceable clearance ? have I over looked it ?
    I'll wait until I have a few comments / opinions before I say why I may have concerns:rolleyes:
    Thanks guys :thumbsup:
  2. stubs300
    stubs300 Senior Member
    2,009
    837
    Oct 30, 2011
    Free America
    Your question is somewhat confusing? Pressed out rockers should slide on & off the shaft with no resistance, like you say, a mil or 3. If they don't, look at the shaft and see if someone's over torqued it and squashed the shaft. Don't forget that the hole holes point DOWN on reassembly. Good Luck
    • Agree Agree x 1
  3. ofb383
    ofb383 Member
    51
    14
    Nov 28, 2019
    UK
    OK, what I'm trying to find out is, are my rockers completely worn out, I don't believe they should move around like that, but I have nothing to compare with or spec to check
  4. Davea Lux
    5,244
    1364
    Mar 27, 2017
    Cornelius Or
    The pressed rockers are held in place by spring tension and the push rods. It is normal for them to have some motion which is why this style rocker is not suitable for high RPM, hi lift applications. If you are running a stock camshaft, the looseness is nothing to worry about. For your own piece of mind, remove one of the rocker shafts and inspect the lower side, as long as there are not deep grooves cut into it from lack of oiling you are good to go.
    • Agree Agree x 3
    • Like Like x 1
  5. ofb383
    ofb383 Member
    51
    14
    Nov 28, 2019
    UK
    Ok, that still looks quite a sloppy set up but I'll pull them and have a look.
    Cam that's gone in is approx .462 / .470
  6. stubs300
    2,009
    837
    Oct 30, 2011
    Free America
    If you look at that video when you wiggle and push on the rocker, you will see that the push rod is compressing into the slack in the lifter. Looks solid to me. The real question to the shape of your valve train is, Do you have any top end knocking/noise going on that would indicate a problem? If it's quite, leave well enough alone.
    • Agree Agree x 1
  7. ofb383
    ofb383 Member
    51
    14
    Nov 28, 2019
    UK
    No noise, was smooth running before I stripped the top end
  8. Lefty71
    Lefty71 Active Member
    218
    82
    Mar 17, 2018
    Ohio
    I think, by design they are gonna still work well although they have become quite sloppy. There is only ever tension, one way, and in one place; the bottom. Stamped factory rockers are on hydraulic set-ups and any sloppiness is taken up by the pump-up lifter. It takes a lot of wear before this becomes a noticeable issue on the brunt of cars. If they are clean, and still difficult to slide rockers or spacers on and off, then someone has ruined the shaft by overtightening.
    • Agree Agree x 2
    • Like Like x 1
  9. ofb383
    ofb383 Member
    51
    14
    Nov 28, 2019
    UK
    I will pull them tomorrow and have a good look over them for the sake of 5 minutes work. The main thing is that it seems this is common for the factory stamped rockers and that they are not just completely worn out.
    Was better to ask you guys than either just carry on or waste unnecessary money on replacements.:thumbsup:
  10. stubs300
    2,009
    837
    Oct 30, 2011
    Free America
    As I always say, If it ain't broke, don't fix it! Good Luck
    • Like Like x 1
    • Agree Agree x 1
  11. 413
    413 Active Member
    352
    144
    Jan 28, 2019
    NW USA
    When the shafts are off of the engine then the stock stamped rockers have lots of movement, they are not tight to the shafts. This is normal.
    Yes the oil hole goes down, but also it is not in line with the bolt holes, so the oil hole goes in towards the center of the engine.
    • Agree Agree x 4
    • Like Like x 1
  12. 1970FuryConv
    1970FuryConv Senior Member FCBO Gold Member
    1,726
    1306
    Aug 8, 2014
    Richmond, VA
    Agree: On 440, oil comes into rocker shaft thru a diagonal passage from #4 cam bearing. The rocker shaft lubes each rocker thru holes in the bottom of the shaft.
    Also agree that the rocker movement is normal.
    Edited due to @Big_John SEE CORRECTION BELOW
    • Disagree Disagree x 3
  13. Big_John
    12,018
    7034
    May 21, 2013
    Marcellus, NY
    They are interchangeable. No left or right.
    You do have to orient them correctly. See the FSM.
    • Agree Agree x 6
  14. stubs300
    2,009
    837
    Oct 30, 2011
    Free America
    Next thing you'll know is that he'll be telling us that the heads aren't interchangeable from left to right!
  15. ofb383
    ofb383 Member
    51
    14
    Nov 28, 2019
    UK
    Maybe he's referring to the fact you could pick up the complete assembly and walk around the car and place it on the other bank?
  16. furious70
    furious70 Active Member
    409
    143
    Aug 18, 2018
    Chitown
    Incidentally, that is true for gen III hemis.
  17. stubs300
    2,009
    837
    Oct 30, 2011
    Free America
    I thought we were talkin about 383's. What's the 3rd Gen. hemi's have to do with the discussion?
  18. furious70
    409
    143
    Aug 18, 2018
    Chitown
    The thread has strayed a bit so I kept the mopar info flowing.
  19. stubs300
    2,009
    837
    Oct 30, 2011
    Free America
    That happens on occasion, the OP doesn't need left turns off topic!
  20. furious70
    409
    143
    Aug 18, 2018
    Chitown
    Apologies chief.
    • Like Like x 1
