1. monaco
    monaco Member
    66
    0
    Aug 24, 2014
    ontario
    Guys
    I'm looking at building a stroker motor with my 400 and would like to use parts from my 383/440's.
    Can anyone give me any direction on a build guide?
    I was told a 470 is the way to go for power and cost.
    Thanks
  2. CBODY67
    CBODY67 Senior Member
    4,838
    1100
    Mar 27, 2011
    Seems like one of the first versions used a 440 crank with the mains machined to 383/400 size? BUT we've progressed FAR from that point by now. Result was something like 452cid? Somewhat doubt you can "shoe string" one of these.
  3. 70bigblockdodge
    70bigblockdodge Old Man with a Hat FCBO Gold Member
    12,277
    5193
    Jan 19, 2013
    Avonmore Pa.
    470/474 is a 400 with a offset ground, 440 crank with Chevy rod bearing sized crank pins. Not cheap. The do make a 3.91 crank that makes this displacement. You would be better off just making a 512 cid same $$ and more common/choices.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  4. carrman
    carrman Well-Known Member
    889
    472
    Jan 1, 2011
    Medford, OR
    I have a 451 in my '68 Newport. Forged 440 crank, 400 rods, and KB251 pistons from Keith Black. Works very well.
  5. twostick
    twostick Senior Member
    2,116
    931
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
    No replacement for displacement and stroker kits are the same price regardless of stroke.
    4.25 stroke is the easiest one to fit for 511 cubes with a 4.375 .035 oversize piston.
    Kevin
