Found 413 Flywheel
amazinblue82
United States
Feedback: 6 / 0 / 0
Looking for a flywheel for 1965 MY, 413 engine with automatic trans.
Shoot me PM if you may have one available.
thank you.
Bump.
Anyone know if there is an interchangability with another year 413?
Thanks for looking.
i've taken the ring toothed flywheel of the converter and turned it to good teeth for the starter to use . you must grind off the welds and pop it off and then put it back on and reweld it as it was . or replace it with another 62-63 converter 318 383 413 426 with a 727tf auto interchanges .
OOhhh .... again excuse my ignorance.
In this year, was the "flywheel" is a ring of teeth around the torque converter? something like this??
yes thats the way mopar did the flywheel on 62 and later autos 727 tf uses a smaller input shaft from 62 - 65 these are cable shifter trannies . 66-78 has mech linkage and has a larger input shaft , but the same looking converters .
