WANTED 440 Exhaust Manifold - RH - Part #2899968 Cast #2899879 and LH Part #3418352 Cast #3418351
Thank you. Yes, I was aware.
I have a RH 2899879 , the heat riser valve has been removed and the holes have stainless steel threaded plugs or bolts in the holes . No cracks that I can find anywhere. $150 US plus the ride .
The plugs are threaded into the push in bushing , the bushing can be removed and new one’s installed when installing a new heat valve . All the bolt holes look good with no cracks.
I cleaned off the numbers as good as I could. I believe the small one is a date code
Either the set or individual. Thank you!
I have 3418351, 440 C Body only with the heat stove. $275 plus shipping or come and get it. It would be helpful to put your town and state down for your location.
for the coin you all want for those parts...do ya thinky it would be possible that you bead blast the manifolds in your bead blast cabinet..protect the finish...then lay a straight edge across the ports........never mind you probably don't know what that is.....
Your rudeness is unacceptable. The left hand HP exhaust manifold is for C Body's with a 440 HP engine (U Code) used only in 1970 & 1971 and it has the heat stove that is always missing. Find me another one at a lower price with a heat stove. I did lay a straight edge across it and I don't own a sand blast cabinet. None are listed on eBay including the completed items search.
