WANTED 440 HP manifold
Mopar Parts Wanted
  1. Shelbyz08
    Shelbyz08 New Member
    0   0   0
    35
    18
    Dec 21, 2019
    Minnesota
    Contact Seller
    Looking for a set of HP manifolds for my 72 new Yorker 440. Something reasonable
  2. hemi71x
    hemi71x Active Member
    Rating - 100%
    5   0   0
    276
    53
    Nov 14, 2015
    Rancho Cordova, CA.
  3. Shelbyz08
    0   0   0
    35
    18
    Dec 21, 2019
    Minnesota
    I need to do some more reserch. Some stuff I read says the 383 and 400 have a different angle on them. I don't know if that's all the years or just the newer ones, cause worst case I have a set on a 73 charger 400 I will slap on was just looking for the c body driver side
  4. LocuMob
    LocuMob Fluid Technician with a hat FCBO Gold Member
    Rating - 100%
    5   0   0
    11,679
    7508
    Oct 31, 2013
    Blue Earth Mn
    Part numbers are the same for both 383 and 440.
    MyMopar - Mopar Forums & Information - Mopar Exhaust Manifold Casting Numbers 1958-1973
    The head pipes off the manifolds will be longer for the 440.
  5. Shelbyz08
    0   0   0
    35
    18
    Dec 21, 2019
    Minnesota
    I looked at that earlier but it doesn't even list the HP manifolds, the manifold I think I wants a 2863409
  6. LocuMob
    Rating - 100%
    5   0   0
    11,679
    7508
    Oct 31, 2013
    Blue Earth Mn
    Magnum is the HP manifolds. But yeah, it doesn't list '72 or newer.
  7. lemondana
    lemondana Member
    0   0   0
    65
    38
    Aug 30, 2011
    The casting numbers on the 70-71 HP left manifolds are NOT the same. The rights are the same for both 383-440 The 383 is 2951216 and the 440 is 3418351. I found that out when I ordered and was installing my TTI exhaust on my 71 Polara in my avatar. The original engine was a HP 383 and I installed a 440. I ordered the exhaust for the 383 manifolds, I knew the casting numbers were different, but I figured it would fit. Luckily TTI sent me the right headpipes for the 440 manifolds. But I wondered why the left pipe wouldn't bolt up to the 383
    manifold. I did a Google search of the 440 3418351 and the picture was quite a bit different that the 383 manifold. I called Murray Park, and he had a nice one for 150.00. Problem solved. Kudos to TTI!
  8. polarus
    polarus Senior Member
    Rating - 100%
    1   0   0
    1,856
    853
    Feb 22, 2013
    72 is an odd ball year, no 440 left side H.P. manifold listed.
  9. lemondana
    lemondana Member
    0   0   0
    65
    38
    Aug 30, 2011
    I would think the 70-71 manifolds would fit a 72, but 73 a few things changed under the hood, so I'm not sure. Years ago I parted a 73 Newport that had a HP 440 with HP manifolds, I didn't mark them, so I'm not sure which ones they are.
  10. polarus
    Rating - 100%
    1   0   0
    1,856
    853
    Feb 22, 2013
    My book lists the 73 C body 400/440 LH HP manifold as part # 3744821, no casting # listed.
  11. Shelbyz08
    0   0   0
    35
    18
    Dec 21, 2019
    Minnesota
    I ordered one from a older c body. So hopefully it fits. I might have to make custom downpipe. It looks like the only differents on the newer c body manifold is the heat riser
