440Source water pump housing GUNK!
Heating, Cooling & AC
  1. 66Newyorker
    66Newyorker Active Member
    313
    176
    Dec 1, 2014
    Louisiana
    After reading a couple of posts about 440Source water pumps housings and causing operating temperature to be higher than normal I decided to remove the one on our New Yorker. After I got it off and checked the output passages (lower) found they were about half as big as the original cast iron housing. Spent the morning swapping them out. Thinking the car should run cooling at highway speed with the A/C on and about 90 degrees plus outside.
  2. Newport 66
    Newport 66 Old Man with a Hat FCBO Gold Member
    5,686
    3774
    Aug 6, 2017
    Lancaster, WI
    Made in China. Even the MoPar Performance ones, that not long ago were made here are Asian made. It's a shame that this stuff can't be made to specs here in the USA.
    If I'm not mistaken, the US Mags I just looked at are made oversees.
  3. 68PK21 440.6bbl
    68PK21 440.6bbl Senior Member
    4,781
    2652
    Nov 29, 2017
    Self Isolation
    :drama: I think Darrel's or Darin whatizname from GYC quote is appropriate.
    "And Walter Chrysler is wrong?"
  4. commando1
    commando1 Old Man With a Hat on the Porch FCBO Gold Member
    33,867
    18813
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    Can't for the life of me understand, with story after story being told about how shitty everything from 440 Source is, people sheep keep buying their crap.
  5. 66Newyorker
    313
    176
    Dec 1, 2014
    Louisiana
    Just got back from a test drive. With the A/C on and 90 degrees outside the car run at 190 degrees. A drop of at least 20 degrees maybe more.
    • Like Like x 4
  6. 66Newyorker
    313
    176
    Dec 1, 2014
    Louisiana
    The one thing I like from 440Source is the adjustable oil pump pressure regulator.
  7. 65Fury440
    65Fury440 Senior Member FCBO Gold Member
    2,451
    1000
    Apr 21, 2013
    West Central FL
    Good deal OP!! That is a huge difference!!
  8. Welder guy
    Welder guy Old Man with a Hat FCBO Gold Member
    6,191
    7422
    Dec 30, 2016
    Millet Alberta
    I need to be educated but why does one need to regulate there oil pressure? I’ve ran a high pressure oil pump since 1998 and it was the best move I made 250,000 miles ago.
  9. Welder guy
    6,191
    7422
    Dec 30, 2016
    Millet Alberta
    That’s great news , stick with the Ma Mopar water pump.they are tried and true !!
  10. 66Newyorker
    313
    176
    Dec 1, 2014
    Louisiana
    It has allowed me to set the oil pressure at what I want. Not just swap out springs. That’s all.
  11. Welder guy
    6,191
    7422
    Dec 30, 2016
    Millet Alberta
    Ok thanks
  12. CBODY67
    CBODY67 Senior Member
    4,570
    1051
    Mar 27, 2011
    Curious . . . what is the desired oil pressure target you have? That you need an additional oil pressure regulator?
    • Agree Agree x 1
  13. 70bigblockdodge
    70bigblockdodge Old Man with a Hat FCBO Gold Member
    12,052
    5054
    Jan 19, 2013
    Avonmore Pa.
    How much, + shipping to PA?
    • Like Like x 1
  14. twostick
    twostick Senior Member
    2,007
    896
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
    It's because everything isn't shitty from there.
    My 493 stroker kit came from there. The crank was checked and needed no correction. The rods weighed what they said to the gram. The big end was correct OOTB. The small end was honed to size for the pins that came with the Ross pistons. My machinist's idea of close enough is measured in ten thousandths of an inch.
    Now their Comp Pro Magnum knock off rockers were unusable OOTB and by the time I corrected all their problems I could have bought the real thing and been still using them. Yep they died.
    That being said while all the other vendors are still selling the same basic piece of crap rocker, Brandon took his off the market.
    Now those Ross pistons didn't hold their expansion tolerance for their piston to wall spec and are now scuffed slightly.
    The Edelbrock heads came with a Briggs and Stratton valve job and the MP M1 intake came nowhere close to fitting OOTB. It took .070" to get it to fit properly. It only took .007" to zero and square the block so was it the intake or the heads that were FUBAR?
    As far as I'm concerned, China doesn't come close to having the poor quality control market cornered just yet.
    Kevin
    • Like Like x 1
  15. 66Newyorker
    313
    176
    Dec 1, 2014
    Louisiana
    I went for about 25-30psi hot idle without the A/C on. Running 10-30 Lucas Hot Rod oil. 440Source calls it a regulator. It is a screw and lock nut allowing your to set your oil pressure. Goes in place of the spring nut on the oil pump. When I first started to adjust the pressure I screwed the screw in too far and had 100 psi.
  16. 66Newyorker
    313
    176
    Dec 1, 2014
    Louisiana
    How’s $25.00 plus the ride.
  17. 65sporty
    65sporty Old Man with a Hat
    7,253
    1795
    Aug 24, 2013
    Kingston, Mi
    I remember reading a post a while ago about one of the water pump housings with too small passages and the poster opened them up to match the original iron housing.
  18. commando1
    33,867
    18813
    Mar 10, 2011
    You want the 440S housing???
  19. 67Monaco
    67Monaco Old Man with a Hat
    5,557
    2577
    Nov 20, 2010
    Punta Gorda FL
    The ports can be opened up. No different than porting a head.
    • Like Like x 1
  20. Turboomni
    Turboomni Old Man with a Hat
    5,075
    2592
    Dec 14, 2015
    MA
    I'm glad to hear this. If my 440 wears out or breaks I would love a stroker 440 with a mild cam with gobs of torque and lots of vacuum.
