61 Chrysler Transmission leak
azblackhemi
Waddell AZ
Because the convertor is draining and raising the level to where it's probably leaking from around the shift shaft seal. Not too hard of a repair with the proper tool.
1970FuryConv
Richmond, VA
413
NW USA
cast iron torqueflight in 1961, drive it more often!
Yes it’s the converter draining back when sitting.
Yes the seals are a totally different thing than a 66 and newer 727.
dipstipck bolts on, no seals. Same idea as a fuel line.
