The '61 plymouths were still set up for a bellows style booster and the linkage is going to be all wrong, so I suspect some considerable modification would be necessary. Power and standard brakes were different setups. You would need to see if the mounting plate for the master cylinder is the same, if it is you might be able to run the '61 pedals with manual brakes. I think that probably is going to be a long shot however.
I have a set of peddles from a 65 ,That I may part with,,it had standard brakes,, PM me if you like. I,m a fair piece from Northern Calif. Next to Buffalo...Catfish...
