65 & 66 Fury Fenders Interchange?????
Fury65
Winnipeg, Manitoba, Canada
Do any of the minds here know for sure whether the 66 Fury front fenders will fit a 65?
If need be, I could change BOTH fenders to eliminate any possible issues!!
I
I once put a 66 fender on a 65 and it was the same except for the trim holes. The side trim was different between the two cars.
FWIT, I took a fender from a 65 4 door (Fury III) and put it on a 66 Sport Fury (2 dr).
Yes you can interchange the fenders,,but,besides the trim and emblem holes you will need to swap the headlight bucket area as they are different,I put a 66 fender on my 65 and while checking for differences between the two I wouldn't of been able to put my headlight trim on as the holes are not the same.
You could modify it or drill out the spot welds and weld in the original one like I did.
