Here's a quick one...can I remove the oil pan from my poly 318 (in a '65 Fury) without lifting the engine up? I know I'll have to at least remove the tie rods center link to lower the pan and get it out. Not sure if there will be enough clearance above the frame member and below the crank to slide it out though???...
Thanks.
J. G.
Thanks.
J. G.
