66 Chrysler 300 Fuel Gage (Not sure if right spot)
Umeracle
UK
Hey Guys im not very mechanical but my fuel gage is not accurate as when I fuel up its either showing empty or full and it will never tell me an accurate reading to whats actually happening so everytime i've been guessing and just fuelling up whenever. What's the best way I can go about this getting it working?
FURYGT
Iron Station, NC
The first thing to check is the ground strap from the tank sending unit to the steel fuel line. Chrysler used a metal strap that snapped over the end of the fuel sending unit output line that goes over the rubber line to the metal fuel line that runs up to the engine. They tend to get rusty or rust away and break. A piece of wire with hose claims on each end will work. If that doesn't work, the float or the sending unit or the dash gauge could be bad. Good luck.
Gerald Morris
Tucson
1.) Check that your gas tank IS grounded.
2.) Next time its good and empty, remove the sending unit. Is it OK? You can get a good replacement on a 66 gas tank for under $50, if you look a little.
3.) Check the voltage coming from your dash at the BLUE wire, connecting to that sending unit. Is it 5-6V? If not, you need a new dash voltage regulator. There are solid state ones now, for again, around $50 I think, or you can get another electro-thermal one like from Standard for ~$10-20. I'd get the solid state one if I needed one. You will need to remove the instrument panel to get to that regulator. That requires a little head standing and contortion. I've done it, and still can, Deo gratias, but not everyone is so blessed.
Instead of mucking with that stuff on my '66 dash, I bought a nice new Autometer fuel gauge made for old MoPARs, ran it on 12V w a new sending unit and drove that car until it was destroyed by an evil succubus last September. I still have the gauge, and plan to keep it until I need it again. It ran me about $60 from Jegs.
