bigblockmopar66
Hey guys. I am having trouble removing the rear window trim on my '66 Newport. Is there a trick or a special tool that I should be using? Thanks for your help.
I just removed all the trim around the windows of my 66' convertible today. I can't speak for your back window but all the other trim was held in place with metal clips so they were the easiest for me to remove. I took a plastic pry tool and just popped each clip.
Thanks for your advice. The trim around my back window is held on by metal clips as well. There is a lip the runs the length of each piece of trim which allows the trim to snap in under the clips. I was able to just slide the two bottom pieces off but the top pieces aren't budging. P.S. What are your plans for your 300?I just removed all the trim around the windows of my 66' convertible today. I can't speak for your back window but all the other trim was held in place with metal clips so they were the easiest for me to remove. I took a plastic pry tool and just popped each clip.
I am doing the bodywork and pulling the 383. After the 383 is out, a 440 is taking it's place (after the engine compartment is done). Then she will be returned to her original color, Crystal Blue. The interior will eventually be redone as well.
