shocktrauma
I need lugnuts to fit my wheels to 66 fury drums, are there any aftermarket lug nuts that will fit my wheels to the Fury. Wheels are off of a 09 charger R/T 18x7.5 any information or help would be appreciated. Thank you
Not to shock with a positive note after I likely traumatized you with my arrogant opinion, but to answer your question... The studs on your Fury will be 1/2", and the threads on the driver's side will be left hand thread.
You may want to change the driver's side studs to RH thread if you end up needing shanked lugs or anything out of the ordinary that may not be available with the LH thread.
I'm sure we all would like to see some pictures and some details of your car.
Definately not for the timid.
Pffftttt...You know I had the idea that this is what you looked like!
I'm not 100% sure but I would think the bolt pattern would be the same, offset another story. Have you had them on the car yet, even without lugnuts?
It's a b body it has rt.hand threads all around
I took pictures 5/21/12 with wheel setting on hub needs very slight milling.
If your Fury is a '65-'74 it is not a B-body.
Also, I trust that Stan actually did the research for you and has stated that the bolt pattern was not a direct match. I suspect your machining comment was to open up the wheel center, but if the bolt pattern is not exact, you risk breaking off studs, or losing lugnuts and possibly killing yourself, or worse, someone else.
There are plenty of ugly aftermarket wheels that will fit your car correctly, so I would suggest that you save your money to go this route and live long enough to enjoy your car.
Since nobody else wanted to, I did some research.
The 09 Charger wheels have a 115 mm bolt pattern which is a scoche bigger than 4 1/2".
Googling has found many posts that people have attempted to use them using a little "persuasion" but it is generally frowned upon and any tire store worth their salt will refuse to mount them.
