The grills are totally different look, however the bodies are the same style so yes it should fit into the opening. Not sure what differences there will be with the mounting points and hardware. There may be some mods required.
I would think they would.
I was surprised at the parts that are different but look like they re the same at first glance, though, like the dash and rear quarters.
They do fit but if fitting a 65 grille into a 66 the bar under the grille needs to be unbolted and removed. Also the two bottom screw holes in the headlight surrounds don’t line up.
