WANTED 67 Fury front sway bar to frame links
edbods
Australia
Am after a pair of sway bar links for a 67 Fury, the ones that hold the square rubber bushings. Would prefer if the welds were already drilled out for easy servicing. Alternatively, if anyone has a PST kit that will accept the factory size sway bar bushings I'd also be interested in that, as PST don't seem to make them anymore.
I have the *** LOWER *** BALL JOINT ASSEMBLIES *** , the *** LOWER CONTROL ARM BUSHINGS *** , and the
*** SWAY BAR FRAME BUSHINGS *** ( and the Entire Front End Components) including the Inner Sway Bar Frame
Bushings and Upper and Lower Control Arm Rebound Bumpers / Bump Stops .....
I already have the bushings, but I just need a replacement bracket for the sway bar x stub frame. One side seems to have been bent and I figured I might as well replace it as I can only assume bending it back would weaken the metal
