'69 300 inner fenders removable ?
5wndwcpe
S.E.P.A.
As I'm better versed in B bodies, I humbly inquire as to whether or not the inner fenders on a '69 300 are removable (easily or otherwise) with the fenders still attached ?
Yes they are.
The FSM should have the procedure, but it's just basically take the wheel off and unbolt it. A couple layers of blue painters tape around the opening is a good idea to keep from scratching anything.
They are simply screwed in. My question is, why would you want to?
I took mine out when I converted to front disks, gave me more room to work. Putting them back in was FUN!!!
Taking them off is easy. Putting them back on is more work. I used a Phillip's head screwdriver to line up one hole, while putting a screw into an adjacent hole. It worked but it took some time.
