70 fury console
Bill fury
Staten Island ny
Like to convert my Fury to a floor shift. I have everything except the shifter, and linkage. Can i buy 70 b body linkage,and shifter since it will be easier to find. Thanks.
There was a thread a while back comparing the B-body shifter and the C-body console shifter. The look similar, but the C-body item is a bit longer, as I recall. Not sure if the unseen parts migh be close enough to work, though?
Can't see the rods being the same. You can use a b&m cable though with a b body shifter. I used a cable because the a500 is too big around for the oem stuff to work
Thanks
Luckily the detents in the shifter were the same as a b&m shifter so it lined up without having to make a custom lever at the trans
