moparblood
did the air cleaner come with black wrinkle paint?
If you desire. Many times, the bolts which hold the shield on are soft and break off in the cast iron, so you might investigate that, too. Also make sure the vac motors which run the flapper doors in the snorkles are working and don't leak vacuum, for good measure. Plus the thermostat in the base of the air cleaner where the vac comes to from the engine.also has the stove pipe on air cleaner and finned exhaust manifold.
so do i need the shield over manifold to hook up pipe?
