727 Output Shaft compatibility
  1. jcslocum
    jcslocum New Member
    13
    6
    Oct 5, 2019
    Eastern Shore, MD
    Hello transmission experts. I have a 1966 Fury 3 (318 Poly) wagon with a blowed up 727 trans. I can rebuild the current '66 727 but it has very limited options available for this year/model, particularly the torque converter. I plan an engine swap later this year so want to upgrade the trans now and use it for the summer.
    I have picked up a 78 727 from a motor home with low miles BUT it has the E-Brake on the tail-shaft. The question, is will my current '66 727 output shaft work with the modern heavy duty 727? I recall reading somewhere that the inner end of the shaft won't match up to gear cluster inside the trans. Does anyone know for sure?? I can pickup a more modern tailshaft and use that but need definitive info on this issue.
    Thanks for any help. I really appreciate it.
  2. 70bigblockdodge
    70bigblockdodge Old Man with a Hat FCBO Gold Member
    11,675
    4798
    Jan 19, 2013
    Avonmore Pa.
    That's the way I understand it. The early and later than 74,75,76 not sure of year exactly spline shape changed. It will go together but is on the clock for possible failure. I would put the 78 front into your case. Better pump support, possible wide drum, and 4 pinion.
  3. jcslocum
    jcslocum New Member
    13
    6
    Oct 5, 2019
    Eastern Shore, MD
    Thanks for the info.
    So, use the new 727 stuff in the front half of the trans and retain the old stuff in the back half.
    So you think I shouldn't worry about a new output shaft?
  4. cbarge
    cbarge World Famous Barge in a Budget FCBO Gold Member
    2,596
    3178
    Nov 22, 2010
    Kingston Ontario Eh?
    From the Poly, what engine upgrade you planning?? LA block? Or big block?
    Frankenstiening the RV trans is not cost effective even if you got it for free it will be a headache.
    Spending a dollar at the tranny shop just to save a nickle.
    Best off getting a early 70's passenger car 727 core and rebuild it.
    Even a Loadflite from a 70's D100 pickup or tradesman van will work.
    Best of both worlds...fits right behind the Poly and broadens your convertor choices.
    We rebuilt a 72 727 and put in a later input shaft. The car did not move..trans was a lump until we put back proper input shaft.
    Hope this helps just my 2 cents
  5. cbarge
    2,596
    3178
    Nov 22, 2010
    ...And in the valve body the 3-2 part throttle kickdown feature not present in his 66 trans.
    I butchered a truck 1973 727 and used parts from it into the BoaB's big block 1968 727.
    But left the input and output shafts alone.
    As you mentioned the RV innards includes the 4 pinion just like the Hemi 727.
    Also today's modern technology and materials clutch band quality is much better.
    • Agree Agree x 1
  6. 70bigblockdodge
    11,675
    4798
    Jan 19, 2013
    Avonmore Pa.
    Yep valve body also from 78.
    Just take the pump and input, front drum
    Not the whole case and what not.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  7. cbarge
    2,596
    3178
    Nov 22, 2010
    tJbRXNrmo7X2FBvSq85S4gpmgc8aVk51fP3YJq6lDm19eR5zMWvr3Prv90AOWPek3mRTVgGt_oFO8E6DD6Oqi8PsfzloksJw.jpg
    Use your 1966 casing but with RV guts.
    Toss the RV rear casing half..
    :thumbsup:
  8. 70bigblockdodge
    11,675
    4798
    Jan 19, 2013
    Avonmore Pa.
    No front half is good casing. Send it to me instead of rising.
  9. cbarge
    2,596
    3178
    Nov 22, 2010
    edited,lol
  10. cbarge
    2,596
    3178
    Nov 22, 2010
    I hope the OP realizes the A/LA and B/RB bell housings has different bolt patterns that do not interchange...
  11. jcslocum
    jcslocum New Member
    13
    6
    Oct 5, 2019
    Eastern Shore, MD
    Actually, I'm going old school Hemi. I have a 354 on the stand with 10:1 pistons mild cam and a 4bbl.
    What if I transplant the RV trans with the new tailshaft. It's a 727 non-lockup trans.
    That is sort of the plan. I was worried about the output shaft not matching.
    Yes, I'm aware that the bolt patterns are different. The "new" RV trans is from a 440/727 combination.
  12. cbarge
    2,596
    3178
    Nov 22, 2010
    So..you answered your own question and still not getting it
    The 440/727 will not bolt up to the Poly--different bolt pattern.
    Yer putting the cart in front of the donkey here..
    A waste of time trying to change the tail stock,output shaft and find out it will not bolt to the Poly.
    Best to take the good guts out of the RV and put them in your 66 727.
    That is a trans I would buy when no longer needed.
    As for the future Hemi,possibly an adaptor plate to match its bell housing or a different trans altogether.
    Done repeating myself :BangHead:
  13. 70bigblockdodge
    11,675
    4798
    Jan 19, 2013
    Avonmore Pa.
    I'm not sure what year the bellhousing is not part of the block and also the crank flange is different on some of those. I'm not too good with their intricacies, others here know better than I do.
  14. commando1
    commando1 Old Man Wearing a Hat on the Porch FCBO Gold Member
    33,145
    18220
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    Lea, take a time out over at the Gold Member Rant thread... :lol:
  15. Lefty71
    Lefty71 Active Member
    231
    87
    Mar 17, 2018
    Ohio
    The spline angle is different on the front of that output shaft, for sure!
  16. twostick
    twostick Senior Member
    1,830
    825
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
    This.
    Look up the procedure to properly swap the later front pump into your 66 trans. It's a common upgrade. Use the later valve body with the part throttle kick down and finish with new bands and clutches.
    4 pin planetaries are highly overrated. The aluminum splines in the hub are the weak link, not the pinions. A super stock racer friend of mine used to remove 2 pinions on a 4 pin set on their AA/SS Hemi and never ever broke a pinion. Stripped out the splines on a few figuring out how many laps they would take before failure.
    Kevin
  17. jcslocum
    jcslocum New Member
    13
    6
    Oct 5, 2019
    Eastern Shore, MD
    Thanks for your patience and info. I will now transplant the newer front bits into the old trans with new clutches and bands.
