Pete Kaczmarski
1975 Plymouth Gran Fury
1975 Plymouth Gran Fury - $7000 (Ridgecrest) hide this posting
< image 1 of 12 >
Former unmarked New Mexico State Police car. Runs and drives great, and has 104,000 miles. Factory Police package car, PK41P5D VIN prefix. Heavy duty brakes, suspension, charging and cooling systems. Has E68 High Performance 400 cubic inch big block engine, with factory installed double roller timing chain, windage tray high pressure oil pump spring, premium piston rings and valves, and the proven Magnum camshaft. Also has factory power steering cooler, and auxiliary transmission fluid cooler. This engine is catalyst exempt, and has a standard dual exhaust system. Overhauled 727 transmission with new torque converter. Rear gear is a 9 1/4" 3.21:1 ratio with sure grip limited slip differential. Tires have over 95% tread. Interior has new cloth seat inserts from SMS Auto Fabrics identical to originals. Interior is extremely clean. Have non cracked dash pad that I will install prior to being picked up by new owner. A/C has a small freon leak. Car had it's first ever re-paint last summer, in the original color, and is single stage enamel, so no clear coat issues to ever worry about. Price is firm at $7,000. Seven 6 zero six zero 8 seven nine 8 eight.
< image 1 of 12 >
