78 C-body wiper repair using B-body parts
Electrical & Ignition
  1. 71NewYorkMan
    71NewYorkMan Member
    109
    79
    Jul 4, 2012
    Rincon, GA
    Many of you know that the 78 C-body intermittent 2-speed wiper system is a one year only orphan system that requires unobtainable plastic parts to repair. There is a well known and documented fix by @1978 NYB and others that describes how to use 77 and earlier c-body parts as a work around.
    1978 NYB wiper woes.
    I Am Absolutely Done With 1978 Wiper Cams
    Before I bought my 78 NYer, I suspected it would not have a functional wiper system. I read all of the posts I could find on the subject, which alerted me to a "rumor" that b-body parts could also be used as a fix. As I happen to have b-body parts as spares for my Cordoba, I decided to give it it a shot. It works! This particular solution requires no fabrication, but a minor change to the donor b-body linkage will be required.
    Some definitions-
    "Sweep"- the position of the wiper arm and direction in which the motor turns (counter-clockwise as viewed from linkage end of motor) in normal operation.
    "Stop"- the position of the wiper arm in either the intermittent or continuous "sweep" cycle.
    "Park"- the position and direction in which the motor turns (clockwise as viewed from linkage end of motor) when system is turned off.
    "Stroke"- The motor motion which changes dependent on whether the motor is turning clockwise or anti-clockwise.
    "Cam"- Plastic/metallic linkage which changes the length of "stroke" dependent on motor rotation.
    "MP"- Murray Park. A well known and respected supplier of used and reproduction Mopar parts.
    Some comparison photos for the hardware-
    My c-body motor left, NOS b-body motor right. My research indicates several different part numbers for the 78 c-body and 78-79 b-body motors, but they are ALL interchangeable.
    Busted c-body link left, busted b-body link right. Notice the 180 degree difference in the indexing of the linkage. This difference is important!
    Busted c "cam" shown on parked motor.
    Busted b "cam" on parked motor.
    Next photo shows c linkage and "cam" on top, b linkage and "cam" bottom. Both of these systems are shown in their approximate "park" positions. Notice the differences in orientation of "cam" and wiper arm mounts.
    Next photo shows left to right- original busted 78 b "cam" fully disassembled, busted 1990's replacement Mopar b "cam" partially disassembled, "MP" replacement b plastic "cam" parts, my busted c "cam" assembled. IMG_1307.JPG
    Now the fix-
    I assembled the "MP" plastic parts to the b body metal base. You must reuse the base, spring, c-clip and ball shown in the disassembled original or later service issue b "cam" shown below.
    My method of assembling the "MP" parts, original b metal "cam" parts, and original c-body linkage-
    Assembled c linkage with reused b "cam" and new "MP" plastic parts-
    Next is the ONE modification you MUST make- file the flat in the index hole of the b-body "cam" so that you may position the rebuilt b-body "cam" as similar to the c-body "cam"- IMG_1322 - file corner.jpg
    • Thanks! Thanks! x 3
  2. 71NewYorkMan
    71NewYorkMan Member
    109
    79
    Jul 4, 2012
    Rincon, GA
    My system ready for installation-
    System installed, wiper arms tinkered, and running for 30 minutes (with me wetting the windshield to prevent drag).
    Engine running, wipers off-
    Wipers on, full "Sweep"-
    Wipers on, "stop" position-
    Return to off / "park"-
    For those of you who have access to the earlier c-body parts to perform your conversion, I wish you success. If you happen to have access to b-body parts, as I have, then this becomes another option. Either way, I hope this thread has been helpful!
    • Thanks! Thanks! x 5
  3. 75LandYacht
    75LandYacht Senior Member FCBO Gold Member
    3,099
    1434
    Oct 1, 2015
    Westchester NY
    Thank you sir, Great info. On another note, what decision have you made regarding your roof? And have you done anything else to the car since her arrival?
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  4. cantflip
    cantflip Old Jagoff with a Hat FCBO Gold Member
    10,116
    5319
    Nov 1, 2015
    Orlando, FL
    • Agree Agree x 1
  5. 71NewYorkMan
    71NewYorkMan Member
    109
    79
    Jul 4, 2012
    Rincon, GA
    Enter my post, then post another to the same thread? Got it. Thank-you!
    • Like Like x 1
  6. 71NewYorkMan
    71NewYorkMan Member
    109
    79
    Jul 4, 2012
    Rincon, GA
    I have created several threads detailing the progress. The engine is running well, a lift survey this past week generated an action list. Ultimately, the roof will return to OEM with possibly an 05-10 300 sunroof. Cantflip has offered moral support and tin for that project!
    78 NYer "Kinda"- So it begins...
    Kinda running better...
    Kinda got a lift...
    • Thanks! Thanks! x 2
    • Like Like x 1
  7. tallhair
    tallhair Rufus "Mod Hair" Firefly Staff Member
    9,034
    2474
    May 12, 2013
    Mascoutah, Illinois
    • Agree Agree x 1
