Hey folks. Ok this is one of the strangest things I have ever seen. Have an '87 5th Ave. Has a 318 and rwd. Converted it from the wonderful lean burn. Used a carb from a '71 318, vacuum distributor, 6 wire plug from an '76 Cordoba, regular silver ignition box and a 2 pole ballast. This basically has nothing to do with it just to be clear it is not the computer problem.
Well it was working fine then dead. And I do mean dead. Put in a new battery with 12.46v. It is like there is no battery in it at all. It has about 6v to half the fuse block. 12v at battery post of alternator, and 2 poles are live, kind of at the plug for the amp, temp gauge circut board. Pulled the amp/temp block out and the poles for the amp gauge showed continuity the shunt leads nada. Put in a good unit. Put in a new lower ignition switch and nothing changes. Head lights do not even come on. The key buzzer works however. Found 1 fuseable link that lost power, put in a new one. The starter relay has 12v at the hot pole. All the leads going into the firewall are live.
Has the original battery cables and nothing has been put in other than changing the ignition. Any idea's other than a bon fire maybe?
