904 Transmission - 1961 Belvedere
  1. Anton Schuster
    Anton Schuster New Member
    5
    0
    Sep 4, 2019
    Canada
    Hi All,
    I am currently restoring a 1961 Belvedere with a 225 Slant and an early A904 pushbutton trans. Unfortunately the A904 gave up the ghost and is non-repairable. Does anyone know where I could get a new OR used transmission for this thing? As some of you may know , there are some key differences that seperate a early pushbutton 904 from later 904s. Id like to keep the pushbutton. I have had no luck finding anything online as of yet. Thanks for your time,
    Anton
  2. Lefty71
    Lefty71 Active Member
    216
    81
    Mar 17, 2018
    Ohio
    Not to send you away, but I do see a lot more pushbutton A904's go up for sale at the For A Bodies Site. Good Luck, Lefty71
  3. Xenon
    Xenon Senior Member
    1,637
    590
    May 12, 2011
    Over Yonder
    WHY would a trans be " non-repairable " ....?
    • Agree Agree x 1
  4. jct
    jct Senior Member FCBO Gold Member
    3,324
    2230
    Jun 11, 2015
    indianapolis
    Maybe cause these new shops don't know how to fix 'em?
    • Agree Agree x 1
  5. Glenner
    Glenner New Member
    37
    9
    Feb 22, 2016
    Vancouver Island
    This is from a friend that has worked on Chrysler transmissions since the 50’s.
    “I don't believe that it’s not repairable unless the case is cracked or badly damaged.
    Over the years I have reconditioned dozens and dozens of these 904’s and have never seen one that could not be repaired. I readily agree that there are differences between early and later 904’s and that he should strive to keep it original.
    To the best of my knowledge all internal parts are still available for this popular transmission.
    I think there is more to this story.”
    Hope this helps somewhat.
    • Agree Agree x 2
  6. Lefty71
    216
    81
    Mar 17, 2018
    Ohio
    If thats the case I'd try A&A or Copes. They can build the ones that handle rockets, and they can build the bone stock ones too, cable shifted as well.
  7. Anton Schuster
    5
    0
    Sep 4, 2019
    Canada
    The case is badly damaged on mine.
  8. Anton Schuster
    5
    0
    Sep 4, 2019
    Canada
    Case is pretty badly Damaged
  9. bluefury361
    bluefury361 Old Man with a Hat
    11,815
    7888
    Mar 9, 2011
    Alabama Gulf Coast
    I have a 61 318 and 904 combo if you might think of going to a V8. It's complete, engine turns. It's from my donor cat so everything you might need is there.
    Very cheap.
  10. Anton Schuster
    5
    0
    Sep 4, 2019
    Canada
    How much would that be ? And is it a pushbutton trans .
