Aftermarket disc brake kit
Brakes, Suspension, Rims and Tires
  1. mag162
    mag162 Active Member
    254
    50
    Sep 26, 2017
    New York
    Need to add Disc brakes up front to my 67 BB Wagon.
    Is there a goto kit that you guys have used?
  2. Welder guy
    Welder guy Old Man with a Hat FCBO Gold Member
    5,861
    6950
    Dec 30, 2016
    Millet Alberta
  3. twostick
    twostick Senior Member
    1,828
    825
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
    Factory 69-73, preferably 73. The spindles are a direct swap and the rest of the parts are readily available at any parts store.
    Kevin
    • Agree Agree x 1
  4. Welder guy
    5,861
    6950
    Dec 30, 2016
    Millet Alberta
    There are several threads about the subject on the forum it’s easy to do a search and read up about it. Many , many members here swapped over to the 73 disc brake set up and I highly recommend the same due to cost and consumable parts availability.Good Luck and post some pictures.
  5. Imperialist67
    Imperialist67 Well-Known Member FCBO Gold Member
    819
    231
    Jul 16, 2013
    Washington, DC
    From the photo, that looks like a great Fury wagon. I can tell you personally that sticking with "strictly stock" disc brake set-up is an expensive/exhaustive proposition for a '66 - '68 C-body. From Budd calipers, to rotors, to those $#*& D-10 pads, it isn't easy. I have managed to stockpile a few replacements for what I have, but it has taken YEARS to find, and I started ages ago when parts weren't so expensive. Good luck with the conversion project, and feel free to post photos. Can anyone tell me what BB wagon stands for?
  6. mag162
    254
    50
    Sep 26, 2017
    New York
    BB stands for BB.
    • Thanks! Thanks! x 1
  7. twostick
    1,828
    825
    Dec 13, 2012
    The only reason to go with Budd discs is if it's a concours restoration. 69-73 disc is the only practical way to go for any drum to disc conversion for a C-Body.
    If you have a 66-68 C with Budd discs and you aren't OCD about originality and actually drive the car, you just change the lower ball joints and then the 69-73 spindles and stuff bolts on.
    Kevin
    • Like Like x 1
  8. mag162
    254
    50
    Sep 26, 2017
    New York
    Nah this is not a concours restoration at all far from it. This is a great driving 67 fury wagon with a worked 440 that I’d feel much safer if it had disc brakes.
  9. 65Fury440
    65Fury440 Senior Member FCBO Gold Member
    2,392
    977
    Apr 21, 2013
    West Central FL
    I went with a Willwood kit, I don't put on many street miles, but the kit was well thought out, nice parts.
    Stops well from high speeds with no fading.
  10. Welder guy
    5,861
    6950
    Dec 30, 2016
    Millet Alberta
    Was it Bolt on or did you have to change the spindles? Do you have any more information about it?
  11. SportFury65
    SportFury65 New Member
    13
    3
    Aug 18, 2012
    Tucson, AZ
  12. saylor
    saylor Senior Member
    2,671
    1010
    Mar 31, 2013
    GARLAND TEXAS BABY !!!
    i used ECI brakes. bolt on. love it. 2nd cheapest to scarebird as far as price.
    like said above ^^ its all posted up and documented here in the forums.
    try not to die -
    - saylor
  13. Dylan Galvin
    Dylan Galvin Member
    95
    69
    Mar 19, 2019
    Arizona
    I can say that the Willwood kit bolts up real easy and slides right onto the drum spindle. I cant speak of their stopping capabilities, because I'm building the engine and trans right now.
