1970 Plymouth Sport Fury GT Convertible - $25000 (Mentor, Ohio)
1970 Plymouth Fury
VIN: PM27LOD282543
condition: good
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 48785
paint color: purple
title status: clean
transmission: automatic
type: convertible
This C-Body was originally a 1970 Plymouth Fury III convertible with a 383 2-bbl and T-3 Sahara Tan Poly paint. Bucket seats and console are factory stock. (See pic of fender tag for complete list of build codes). This car was purchased in 2006 from the previous owner from California. My friend and I owned convertible E-Bodies when we were younger and wanted to get back into the car hobby with another Mopar convertible without breaking the bank. When we purchased the car, we wanted to simply repaint and drive it. What started out as a simple "re-paint and drive project" turned into a stub-frame off, rotisserie restoration, substantially completed in 2009. Since August 2015, it has been stored in a garage under a car cover and has not been driven.
INSPIRATION/BUILD-OUT
C-Body fuselage cars are less popular than the E-Body and B-Body cars of the late 60s/early 70s, but the Sport Fury GT was a member of Plymouth's Rapid Transit System and held its own as the businessman's muscle car.
The inspiration for this one-off "what-if" car was largely from prior E-Body convertible ownership back in the day. While Plymouth made a Sport Fury and Sport Fury GT in 1970, it never made a regular Sport Fury Convertible or GT Convertible. We restored this car as if Chrysler would have built one in 1970, right down to the C-7 In-violet paint.
This car came from California and was substantially rust free when we got it. All the restoration work on this car (other than the interior and convertible top) was performed by us. Other than the front fenders, sheet metal, floor pan, trunk pan and stub frame are original with some bodywork done to right rear quarter panel. We should have restored the interior ourselves, too, as it turns out, because the interior shop did sub-standard work. (The shop went under shortly after completion). I have included a few pics of this car during the restoration. More available upon request.
Below is a list of significant restoration build out details and parts used to make this a one-off "what-if" car:
- 1975 Truck 440 (rebuilt with mild cam) and Holley Thunder series AVS carburetor;
- 1970 correct cast iron intake manifold, exhaust manifold, valve covers and air cleaner with Super Commando pie plate;
- Sport Fury front grille, hide-away headlamps, rocker moldings, front fenders and turn signals from a donor car;
- Clean dash pad (no cracks) from a donor car;
- TA/AAR style side exhausts with MagnaFlow mufflers (Fury factory performance exhausts exited through the rear valance);
- 2.76 Posi, 8.75 rear end (provides for great cruising speeds at moderate RPMs);
- New front end suspension parts, rear HD leaf springs and all new shocks; and
- C-7 In-violet paint with NOS GT strobe stripes.
DRIVEABILITY
This car was built by us to drive. Since completion in 2009, we have driven it approximately 10,000 miles. In my opinion, the Fury drives surprisingly well. BF Goodrich 235/70 - 15 tires have a lot of tread left on them and new shocks, front end parts and rear leaf springs add to the driveability.
NEEDS WORK
This car isn't perfect and is NOT a trailer queen. Our restoration focused on the major build out concerns, including rust-free body, workable drive-train and aesthetics. Below is a list of significant shortcomings and work yet to be completed:
No A/C Compressor, Blower Motor or Heater Core. The heater core had evidence of leaks and we never reinstalled it. Because we don't drive this car in the winter or cold weather (this car lived in Florida after restoration), we never missed heat. A/C wasn't missed either because we drive this car primarily in the nice weather with the top down.
TorqueFlite Transmission. The TorqueFlite 727 transmission is original to the car and has not been rebuilt. We had the transmission inspected before reassembly of the drive train and was told there were no major issues with the transmission, just normal wear with no signs of abuse. Rather than rebuild it, we decided to drive it and rebuild it when required. A testament to the quality of these transmissions, it hasn't failed and still shifts smoothly turning the 2.76 posi rear. The transmission does have a minor leak from one of the cooling line connections.
Interior. Originally black, we had an interior "expert" do an interior color change to white. The work is substandard and the quality of workmanship was not what we bargained for. While usable, the interior could use work, such as new door panels, seat foam and white headrests and sun visors. I understand that the headrests and sun visors are the same as the B-bodies.
Brakes. This car and the driver could benefit from disc brakes. Currently, the car has drum brakes on all four wheels. The drum brakes seem to be underpowered for the size of the car.
Weather Stripping. The weather stripping for the windows should be replaced.
Steering Wheel. For whatever reason, the steering wheel appears to be from a '69 B-body. Works fine and looks okay, but could use a '70 wheel.
Speedometer Cable. Needs new cable. Odometer does not reflect accurate mileage.
Headlight Motor Bracket. We don't have a headlight motor bracket. The donor Sport Fury did not come with a motor or bracket. Headlight doors are manually held open to drive at night.
Bottom line is this is a really solid car, tastefully restored and likely one-of-a kind with many years left to drive, work on and enjoy. If you have any questions or would like to discuss, please feel free to contact me any time via phone or text. Fore four oh, ate too three, two three nine sevin. Happy to fill you in on more details. Price is negotiable and I really would like to sell this car to the right buyer for a fair price. Bring a trailer or drive it home.
Thanks for looking,
Greg
THIS CAR IS BEING SOLD ON AN "AS IS, WHERE IS" BASIS AND THE SELLER MAKES NO REPRESENTATION OR WARRANTY OF ANY KIND WHATSOEVER, WHETHER ORAL OR WRITTEN, EXPRESS OR IMPLIED, STATUTORY OR OTHERWISE (INCLUDING WITH RESPECT TO MERCHANTABILITY OR FITNESS FOR ANY PARTICULAR PURPOSE), AS TO ANY MATTER CONCERNING THE CAR OR THE ACCURACY OR COMPLETENESS OF ANY INFORMATION PROVIDED TO THE BUYER IN CONNECTION WITH THE SALE OF THE CAR OR OTHERWISE AND ANY SUCH REPRESENTATIONS OR WARRANTIES ARE EXPRESSLY DISCLAIMED.
