Hemitom
I have looked all over for an answer to this with no luck. I'm still trying to learn a lot more about the 70 Fury convert that I'm getting. I just found out it has front power drum brakes. I know there is conversion kits out there and there is using 72/73 parts on the 70. now my question is if i go the 72/73 route do i have to change the spindles or can I still use the one on there already?? Will the 72/73 rotors work on the spindles without any modification?.
now would you have to replace the master cylinder when changing the rotors or can the original one work?? basically what is comparable with what I got compared to what im going to use in the conversion??
:sSig_thanks::sSig_thanks: in advance!!!
