66Fury383
My Fury has 2" drums on the rear, and because they are fairly uncommon, I am considering upgrading to a better/more common size. Has anyone done this? What all is involved?
Mine are the 11x2 light duties. (2in pad, ~2&1/4in drum)On Chrysler's they ran either 2-1/2 or 3 inch rear drums. (3 inch were tow package or cop duty brakes not cheap since the Road Runner,and Hemi B bodies run the same set up.)
To upgrade to those sizes make sure you grab the matching backing plates to fit properly.
Another recommendation is if you want to go to that extent of pulling axles to swap backing plates,do a rear disc brake swap.
Done
What did you have to do axle-wise?Swapped mine for 2 1/2” a couple of years ago when I pulled the drum assembly from a 73” Chrysler
Was a very easy conversion
Nothing required other than swapping out the drums, backing plates and wheel cylindersWhat did you have to do axle-wise?
