AT cooler line removal?
Fuselage Years
  1. B-Rode
    B-Rode Member
    74
    17
    Jan 19, 2018
    Minnesota
    Hello,
    Is there a trick to removing the transmission cooler lines from the radiator?
    Thanks!
  2. 68PK21 440.6bbl
    68PK21 440.6bbl Old Man with a Hat
    7,158
    4409
    Nov 29, 2017
    Siren City
    Flare nut wrenches are your friend, (the kind for brake lines) Plus a little spot of torch heat as the tube can rust up solid to the nut as it looks like yours already has by looking at the twisted collapsed tube. Just a quick spot of heat on the nut before you turn it should free it of the rust bind.
    • Agree Agree x 1
  3. Davea Lux
    8,711
    2122
    Mar 27, 2017
    Cornelius Or
    Hitting the connector with a shop of good penetrating oil also helps.
    • Agree Agree x 1
  4. Big_John
    15,040
    9497
    May 21, 2013
    Marcellus, NY
    One trick I learned from a friend is to lay a hammer against the flat on one side of the hex and rap the opposite side with another hammer. Works almost every time.
    That said, that line is toast.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
  5. 413
    413 Senior Member
    1,074
    333
    Jan 28, 2019
    NW USA
    You hold the brass part with a 1/2” open end. You turn the large Nut with a 5/8” wrench. Go back and forth if it won’t spin on the tube.
    looks like an aluminum rad. Also looks like it has been sprayed with something.
  6. 70bigblockdodge
    70bigblockdodge Old Man with a Hat
    12,896
    5605
    Jan 19, 2013
    Avonmore Pa.
    Just twist it out/snap the line. Throw it away and replace with female brass inverted flare. Then use 3/8 line with regular male nuts on the line. Next time you will be able to use 2 flare wrenches.
    Not one of Chryslers better ideas, but what do they care they don't have to work on rusty cars only new.
    I do like the double hammer idea from Big John. Have to try that on my Challenger on cam swap.
  7. 1970cat
    1970cat Senior Member FCBO Gold Member
    3,496
    1526
    Dec 10, 2012
    central ny
    big john is right , as usual. that top line is pinched nearly shut.
  8. savoy64
    savoy64 Member
    128
    30
    Mar 9, 2019
    80537
    tighten slightly.....
