Hello guys, new here, what a great site. Im in need for some help on a bb 400. I have a 400 out of a 76 doba and would like to put it in a 68 ny two door. I dont have the funds to build a stroker, vary limited. looking for bottom end with great thottle responce and torqe, here are the details.
VEHICLE INFORMATION
Vehicle Year: 1976
Vehicle Make: chysler
Vehicle Model: cordoba
Vehicle Weight:
Vehicle Transmission: Automatic
Transmission Stall Speed: factory
Vehicle Transmission Model: 727
Vehicle Gear Ratio: 391
Tire Height:
Vehicle Intended Use: Oval Track
Vehicle Requires Inspection: No
ENGINE INFORMATION
Engine Year: 1976
Engine Manufacturer: chrysler
Engine Factory Cubic Inches: 400
Engine Current Cubic Inches: 400
Engine Compression Ratio: factory
Piston Bore Diameter: stock
Connecting Rod Length: stock
Crankshaft Stroke: stock
Desired RPM Range From: 0
Desired RPM Range To: 5000
INDUCTION
Intake Manifold Type: rpm performer dual
Ported Cylinder Heads: No
CYLINDER HEADS
Cylinder Head Manufacturer: 452
Cylinder Head Material: Cast Iron
Head Runner Volume: stock
Intake Valve Size:
Exhaust Valve Size:
Ported Heads: No
Rocker Arm Ratio: stock
Adjustable Valvetrain: No
Maximum Valve Lift Capacity:
FUEL DELIVERY
Fuel Delivery System Type: Carbureted
Fuel Injector Or Carb Size: 4 barrel 600 vacuum sec
Fuel Type: Pump Gas Unleaded
Fuel Octane Rating: 91
POWER ADDERS
Super Charger: No
Super Charger Type: Centrifugal
Supercharger Boost Amount:
Turbo Charger: No
Turbo Charger Count: One
Turbo Charger Size:
Turbo Boost Amount:
Nitrous: No
Nitrous Amount:
Nitrous Stages:
CURRENT SETUP
Current Cam Manufacturer: stock
Current Intake Duration:
Current Exhaust Duration:
Current Advertised Intake Duration:
Current Advertised Exhaust Duration:
Current Intake Valve Lift:
Current Exhaust Valve Lift:
Current Lobe Separation:
Current Intake Centerline:
Area For Improvement: More Low RPM Power
COMMENTS
Comments: I also have a set of 906, 516 heads
They recommended a 60301 kit.
i entered a rpm intake, but not sure. i have several 2 and 4 barrel intakes as well. what would you suggest for intake and carb. any other recommendations would be great
VEHICLE INFORMATION
Vehicle Year: 1976
Vehicle Weight:
Tire Height:
ENGINE INFORMATION
Engine Year: 1976
INDUCTION
CYLINDER HEADS
Intake Valve Size:
Exhaust Valve Size:
Ported Heads: No
FUEL DELIVERY
POWER ADDERS
Super Charger: No
Turbo Charger: No
Turbo Charger Size:
Turbo Boost Amount:
Nitrous: No
Nitrous Amount:
Nitrous Stages:
CURRENT SETUP
COMMENTS
