For Sale Bendix power brake booster for C-body
Mopar Mechanical Parts For Sale
  1. NC-Mopar
    NC-Mopar New Member
    0   0   0
    8
    3
    Apr 17, 2018
    Raleigh
    Contact Seller
    Bendix power brake booster, 1971 and up C-body, single diaphragm front disc/rear drum
    surface rust removed and primed, rebuilt by Prior Industries
    Chrysler #18268
    Bendix #12886
    $175 plus shipping from Raleigh, NC
  2. JPMODL
    JPMODL Member
    0   0   0
    189
    252
    Nov 3, 2016
    WI
    Checking with the experts...will this be correct for '70 Fury GT?
    John
  3. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    0   0   0
    3,542
    900
    Mar 27, 2017
    Cornelius Or
    The booster in the 2nd photo is a dual diaphragm bendix booster. That much is correct, the unit has the large diameter check valve which was not used much on the SFGT, more common on Imperials. It will work just fine, and it would not surprise me if some line someplace built SFGT cars with this booster. Which vacuum accessory is running off the secondary port for the check valve?
    The freshly painted unit in the first photo is not correct for this application and will not fit.
  4. JPMODL
    JPMODL Member
    0   0   0
    189
    252
    Nov 3, 2016
    WI
    I believe I will just send mine in for a rebuild.
    John
  5. Davea Lux
    0   0   0
    3,542
    900
    Mar 27, 2017
    Cornelius Or
    Booster Dewey does a really good job on these boosters. www.boosterdeweyexchange.com.
    Before springing for a new booster, check the vacuum hose to it as the internal lining of the hose sometimes seperates and collapses, starving the booster for vacuum.
  6. JPMODL
    JPMODL Member
    0   0   0
    189
    252
    Nov 3, 2016
    WI
    Thanks Dave
    I will check the hose
  7. Ross Wooldridge
    Ross Wooldridge Senior Member FCBO Gold Member
    Rating - 100%
    1   0   0
    2,178
    580
    Apr 25, 2016
    Brantford, Ontario, Canada
    1970 I believe was a transition year from the dual diaphragm to the single diaphragm booster in the first post.
    Depends on build date and booster inventory at the assembly plant. Both should work on a 70 SFGT.
  8. Davea Lux
    0   0   0
    3,542
    900
    Mar 27, 2017
    Cornelius Or
    That was 1971, all '70's had dual unit with disc brakes.
    • Agree Agree x 1
  9. NC-Mopar
    NC-Mopar New Member
    0   0   0
    8
    3
    Apr 17, 2018
    Raleigh
    $160 plus shipping
  10. NC-Mopar
    NC-Mopar New Member
    0   0   0
    8
    3
    Apr 17, 2018
    Raleigh
    $150 p/s
  11. 66Fury383
    66Fury383 Member
    0   0   0
    134
    56
    Aug 7, 2018
    Kansas City, MO
    Is this still for sale?
  12. NC-Mopar
    NC-Mopar New Member
    0   0   0
    8
    3
    Apr 17, 2018
    Raleigh
    Yes, still for sale
  13. 66Fury383
    66Fury383 Member
    0   0   0
    134
    56
    Aug 7, 2018
    Kansas City, MO
    Check your PM
