Bess's Brakes Pulling Left
Brakes, Suspension, Rims and Tires
  1. Mick
    Mick Member
    188
    38
    Apr 2, 2017
    Louisville, Kentucky
    Evening everyone,
    Need some wisdom. Low mileage 1966 Imperial with power drum brakes. Long story short, she pulled RIGHT when I first got her. Turned out she had a warped right drum. leaking LEFT brake cylinder, and suspect brake hoses.
    Replaced:
    1. Front brake cylinders.
    2. All three brake hoses.
    3. New shoes up front.
    I eventually sought a replacement right drum after turning a couple times, but ended up using a rear right drum and pressing out the old hub.
    Now she pulls left, even with both adjusted really close.
    One thing I did NOT do, was have the LEFT drum turned to more closely match the right. The FSM lists checking for matched drums and worn suspension components under possible causes of brakes pulling.
    Should I expect the self adjusters to compensate, or is that unrealistic? I do plan on matching the drums up before I mess with the suspension because she tracks perfectly and has no other handling issues.
    Any thoughts or experiences with this?
  2. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    3,884
    964
    Mar 27, 2017
    Cornelius Or
    Assuming no suspension/alignment related issues, when a vehicle pulls to the right or left, that usually means the the brake on the other side is not functioning correctly. Start by checking the adjustment, both sides should be the same. Are the brake shoes properly installed? Are the brakes properly bled?
    If one set or the other has the shoes installed backwards, that will cause pulling, the brakes will also pull if both primary shoes have been installed on the same side. Both front drums should be turned the same amount for best brake performance. As the shoes wear in due to mismatched turning amounts, the pull will eventually disappear, but it is better to have it right to start with.
    • Agree Agree x 2
    • Like Like x 1
  3. Mick
    Mick Member
    188
    38
    Apr 2, 2017
    Bleed went fine, but will have to eyeball the shoes just to be completely certain. Thank you.
  4. Zymurgy
    Zymurgy Old Man with a Hat FCBO Gold Member
    5,769
    4179
    Sep 14, 2012
    London, Ohio
    I agree with @Davea Lux comments, especially that the primary shoe is in the forward position (which is not the larger of the 2), I know this from first hand experience. Also make absolutely sure your distribution block is feeding the brakes correctly, again another thing I screwed up.
    Compare all this to the SM because the PO may have installed something incorrectly throwing everything off.
  5. Mick
    Mick Member
    188
    38
    Apr 2, 2017
    Thank you. I had this exactly backward in my head (primary shoe position). Will check.
    • Like Like x 1
  6. Zymurgy
    5,769
    4179
    Sep 14, 2012
    London, Ohio
    I am glad I am not the only one, I had mine wrong for 6 years. It always pulled to the right until I changed to discs on the front, then I had heat issues in the back, until I switched them a few weeks back.
    • Like Like x 1
  7. Ross Wooldridge
    Ross Wooldridge Senior Member FCBO Gold Member
    2,217
    590
    Apr 25, 2016
    Brantford, Ontario, Canada
    Also check for brake lining contamination - pull the drum and see if there's a leaking wheel cylinder - if it was stopping straight after dealing with the RH issues, THEN started pulling left there may be new leak issues.
    • Thanks! Thanks! x 1
  8. rkrochen
    rkrochen Active Member
    351
    229
    Jun 29, 2015
    Teulon, Manitoba
    Lots of people make the mistake installing the shoes incorrectly. I even saw a mechanic on one the tv shows tell people this was the correct way to do it. Obviously I don’t watch that show anymore.
    • Agree Agree x 1
  9. Ross Wooldridge
    2,217
    590
    Apr 25, 2016
    ...and as pricey as they may be, Craig @mobileparts will have ALL the right parts in stock.
    You do get what you pay for in that regard.
    • Agree Agree x 1
  10. Mick
    Mick Member
    188
    38
    Apr 2, 2017
    Thank you, Ross. Thanks everyone.
  11. Mick
    Mick Member
    188
    38
    Apr 2, 2017
    Update: Turned the left front drum and now she's straight!
    • Like Like x 3
