You can find a live ignition source (both start and run together) at the bulkhead. I believe it's blue but I'd probe the wires to be sure. What ever color goes to the voltage regulator or alternator field is the one you want. You will surely need two relays, one 30A for the pump and one 15-20A for the TBI. Read the instructions carefully if your unit supports a fuel pump, cooling fans and A/C. These supply wires trigger voltage to relays only and should not be connected to the loads directly. All heavy sources of 12 volts should be directly off the battery ( just like MSD components) and fused accordingly. It is wise to install a separate proprietory ignition relay because it's very easy to overload the ignition circuit. Although there is usually only the coil,distributor, start relay, alternator and ballast on this circuit, the feed wire is quite a light gauge. A dedicated "ignition feed only" relay offers the opportunity to control other relays downstream for future expansion and takes the load off the existing ignition wire. It too will require a dedicated feed and fuse from battery source which is easy to connect to the battery terminal at the starter.
