mr. fix it
I have run into a big bump in the road for my Stub Frame project that everyone has been following.
My Poly 318 is in need of a total rebuild to make it proper.
I was hoping for a cleaning & re-seal of the engine but
The mains & con bearings are worn.
There is babbitt in the oil pump pick up which looks to be from the main thrust bearing
The cam is done.
Compression was done in 2 cylinders @90psi pumping up when I added oil to 120psi which is across the board for the rest of the engine
For a correct rebuild it is estimated at $3,500 max with an estimated low end of $2500...
The $3500 covers balancing, blueprinting, decking the block & heads, new pistons, boring, etc - the whole 9 yards
the $2500 & under version is the basics.
I know I can get away with not balancing or the blueprinting
This is going to put a big dent in the project.
Most 318 poly owner's in the area think their old rusty looking engines with 70,xxx + miles are worth the world & to buy a used one is a crap shoot.
I may just clean the engine as best as possible and put it back together for now and rebuild it another year.
It's the perfect time mechanically to do it now with the front end off but I just really don't have the funds for this right now.
Any thoughts on how I should approach this?
I want to approach this with a level head here, not just wanting to vent about it.
I'm not going to run out & break the bank or scrap the car just because of this - Thx
The cam is done.
