Chris1966Newport
Hi Everyone,
I picked up a 1966 Newport a few weeks ago, last night the brake pedal went to the floor so i found my first project. It looks like there is some fluid on the inner rear tire so i assume that wheel cylinder blew.
The car currently has 4 drums, no booster, and a single pot master cylinder.
I bought new wheel cylinders at NAPA. The rears are a 15/16th bore, and the fronts are 1 1/8 bore. Does this sound correct?
I also bought a dual master cylinder to split the brakes. I got a NAPA P1874M (I asked for the part for a 1967 Newport with manual drum brakes) This has a 1 inch bore. Does this sound right? This will use the same brake rod as my current master?
Just hoping someone can spot check this before i take too much apart.
Thanks for all help!
Chris
Chris
