Break Light issue 1966 300
Electrical & Ignition
  1. Ralph Johnson
    Ralph Johnson New Member
    16
    3
    Aug 9, 2018
    Pahrump Nevada
    I have just developed a break light issue that has me stumped on my 66 300. All the back lights on the right are functional. On the left all lights work expect the break lights. The left turn signal and lights work however the left break lights don't work. I tried replacing the bulbs but have the same results. Looking for some advise. I did down load the wiring diagram but haven't tried tracing wires back .
    Thanks for all the replies. I found the dark green wire that runs from the turn signal switch was pinched inside the steering column. It was caught between the column and the cancelling unit.
  2. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    4,983
    1299
    Mar 27, 2017
    Cornelius Or
    The brake lights are wired thru the turn signal switch, most likely there is a problem with your turn signal switch since the brake lights and turn signals use a common wire once the circuit is past the turn signal switch.
    • Agree Agree x 5
  3. Lefty71
    Lefty71 Member
    187
    68
    Mar 17, 2018
    Ohio
    Brake light switch (by the pedal) operating correctly?? Nevermind, i guess you are saying the problem only occurs on the left side, right side works fine??
  4. bluefury361
    bluefury361 Old Man with a Hat
    11,659
    7702
    Mar 9, 2011
    Alabama Gulf Coast
    The turn signal switch feeds the brake light switch. If one side is working then it should be ok. If the other lighting works on the left rear then the ground is ok. The left rear also feeds the right rear. My guess is a open circuit, (cut or broken wire) feeding the left bulbs beyond the right side split.
  5. Gerald Morris
    Gerald Morris Well-Known Member
    762
    186
    Mar 9, 2016
    Tucson
    Check voltage on each wire on your left rear lights. Get a pal to press the brakes for you or improvise some other means of closing the brake light switch. I suspect your trouble resides in the trunk on the left side. I get these problems ever so often, and usually can re-seat or rewire the malfunctioning member sans difficulty.....
  6. Ralph Johnson
    16
    3
    Aug 9, 2018
    Pahrump Nevada
    Thanks it turned out that a wire was caught between the turn signal cancelling unit and steering column.
    • Thanks! Thanks! x 1
  7. Ralph Johnson
    16
    3
    Aug 9, 2018
    Pahrump Nevada
    Thanks for everyone's help.
  8. WSP
    WSP New Member
    6
    1
    Oct 9, 2019
    AZ
    My 68 had exactly same problem. Broken wire at turn signal. But since the turn signal canceling cams were broken anyway, I am replacing the whole unit and harness with a repop.
