You had an old style regulator, which has sentimental value and if you have an original car, possible monetary value but ONLY then. There's a fellow in this forum who sells voltage regulators. His eBay page lists them as out of stock right now (FuryGT) but I see some that look quite similar here:
Chrysler Plymouth Voltage Regulator Electronic Solid State Dodge Mopar Body A B | eBay
Best of all, these are made in the good old U.$.A.and are the best you can get for the $ right now!
I bought one after 2 sino-excrement ones from Vatozone gave me dismal results. DON'T WASTE a cent on that **** bro. Get the good ones I mentioned.
I had a nasty short in an alternator not long after I bought my 66 Newport 3 yrs ago and had to rewire a fair portion of the power circuits under the hood and dash. I still have some vestiges of that fire, but have had a safe, functional harness for over 3 years despite these. While working on my steering this Turkey Day I got the chance to clean up some of my "temporary" connections, making for a safer ride yet.
I use VatoZone's crappy alternators for the present only because they honor the "lifetime warranty" for me without argument. On average, about every 9 months I get a new one, all included in the initial $60 + tax I paid for the first one. If you can afford better up front, go that road, but if you're Low Budget as I am, then this deal can be worked to your advantage, provided it doesn't burn the rest of your wiring harness.
To avoid that, be SURE to have fusible links in place protecting all your primary power circuitry. Let NO conductor go unprotected beyond the one to the starter motor, which is momentary contact. I still keep a sharp eye on that one and protect it with secondary insulation over most of its length.
Whatever you do, try to get the best quality parts you can afford. Upgrade when you can. I do, when I can. Low quality always runs more in the long run, so bear that in mind when you get cheap crap. I barely got a month out of some sino-**** bearings vended by Guess Who? before I HAD to replace them with the Timkens I had the sense to get soon as I could. Good thing that too, as I was working; using the car for the job and couldn't afford a lost day.
Some local motor shops can rebuild an alternator competently for you. If you know of one, take a core to them and work a deal. You can often get a shop to rebuild one with a heavy duty stator, diodes and such for a few bucks extra for those parts. I don't need more than 60 amps yet, so I do alright with Duralaughs for now....
