Mike McGuire
Hey Everybody,
HISTORY:
It started out as chasing down why my headlights don't work.
The head lights initially (as received with Rupert) only worked on high beams only, leading me to start with the hi-low dimmer switch (on the floor).
The wiring looks fine, and checking out the functionality of the switch (looked good), swapped it anyway to remove that suspect from the list.
(Ohm-ed out the bulbs too, all good)
After replacing the foot switch, a test revealed that none of the head lights worked at all. I rechecked the switch and connectors and they appeared ok, glad I didn't fumble that.
While wondering what happened, I jostled the under dash harness around a bit and viola the head lights returned to the ON state, briefly.
This lead me to investigate wiring around the fuse box. This turned out to be a dead end as all looks great for the year, nothing rotted, mouse chewed or melted.
Then I lost the tail lights, and rear parking lights.
At this point, I thought, best to return to basics, and removed the dash (lowered the column a bit) to get at the connectors.
(I pinned out the head light switch, all looks good).
On the red side of the ammeter 12V, on the black side 11.3V. A little while later 0V. A little while later the voltage at the black terminal reads 11.3V again.
Then the red terminal read 0V.... (now I am going full nuts), then 12V again 5 minutes later...
I checked the lower part of the fuse box and when the key is 'ON' the accessories all read 12V, which I think is good, (pretty sure). (wipers work, etc.)
The other half reads 0V. Checking the black ammeter lug, it reads 0V, then 4.6V, then 11.3V again... I rationalized the ammeter is bad. (?)
I have an extra dashboard, and am considering an outright swap, as replacing the ammeter itself doesn't look straight forward.
For trouble-shooting purposes I am considering just landing the black and red ring lugs on the red terminal.
Also considering bypassing the bulk head altogether to remove that connection from the list as well, while continuing the game of hide and seek with the head light fault.
RANDOM RAMBLINGS:
I can't help to think there's another component in the puzzle. Why did the tail lights work at all? The head lights probably go through another bulk-head connector on the fire wall, where the aft lights route interiorly...
Might also be a good idea to clean the connector conductors and hit em with di-electric grease. A couple are cracked along the outside, assuming someone was here before and the ears got the screw driver.
hopefully someone makes reproduction connectors I can swap over out. I assume regular needle nose pliers can push the conductor fingers back out... Is this what crappy ammeters do?
So here's what I'm, planning to do:
1. bypass the ammeter
2. bypass the bulk head - (aka CBarge post)
3. clean the snots out of the bulk head connectors
Question - Does this sound like normal logic or am I missing something else here?
Thanks,
Mike
HISTORY:
RANDOM RAMBLINGS:
Thanks,
Mike
