console mounted vacuum gauge -- hose specs?
Early C Bodies - The Slab Side Years
  1. Mike McGuire
    Mike McGuire Member
    182
    36
    Aug 1, 2016
    new hampshire
    Hello Mopar friends,
    The small hard plastic hose mounted to the engine and connecting to the fire wall is ancient and cracked etc. and in need of replacement on my 68 H-code. I might as well replace the interior side while I am at it.
    Does anyone know the diameter, or better yet, a place to order some of that hose?
    Thanks,
    Mike
  2. LocuMob
    LocuMob Fluid Technician with a hat FCBO Gold Member
    12,860
    8473
    Oct 31, 2013
    Winnebago Mn
    If it's standard vacuum hose, any parts store should have it.
    • Agree Agree x 1
  3. Mike McGuire
    Mike McGuire Member
    182
    36
    Aug 1, 2016
    new hampshire
    Yeah, I can always give that a try. Although I've never seen it at an auto parts store, maybe it is kept out of site... Perhaps it isn't standard vacuum hose, more like 'line'. Hard plastic, (maybe) I'd say less than 1/8th inch inner diameter...
    Mike
  4. CBODY67
    CBODY67 Old Man with a Hat
    6,181
    1399
    Mar 27, 2011
    Most auto supply stores (not necessarily the retail chain stores) usually have rolls of vac hose in the back. Take a piece to match. The thicker-walled it is the better as some of what they might have can be very thin and can collapse under vacuum. Might even opt for some reinforced fuel line in the correcrt size?
    • Agree Agree x 1
