Rusty Muffler
Well I managed to do a swap from my stock manual brakes to power on my 66 Fury III. It took getting a power brake pedal and backing plate off a donor 66 and a rebuilt booster and master cylinder from Oreilly's.
Everything fit like a glove as I wanted a bolt up stock setup. My problem is during a road test the brakes were slow to release (about 3 sec) as was the pedal to lift back up to it's home position. The stopping power was fine.
After a lot of haggling I just took off the master cylinder and tried the pedal again on the car with vacuum and it was the same. If I grab the pedal with my hand to pull it home it has a lot of resistance.
I disconnected the pedal from the booster and the pedal is totally free.
Any ideas?
Any ideas?
