I have a 72 fury
I have a 72 fury
Wow!! Seems like a LOT of stuff... perhaps it would be easier to just scrap the original stuff and get something modern... I was really hoping for a/c this summer but the budget and the time are kinda limited.... i suppose i could start by seeing if it even holds vacuum....
Orange county is driving distance to Mexico, the still have R-12 available there. You would need a speaker fluent in Spanish to communicate what you need. He/She should also know a safe area so you do not get any fingers mailed home.
If you where to use a NOS hose I think it would leak like everyone says because it has never had years of oil running through it becoming the barrier.
About 20% less weight because the molecules are smaller in 134 than the giant R12 molecules. The volume will actually be more if compared side by side. This makes the 134 run at a higher pressure when the system is running.R-134a will take about 20% less gas than the R-12 spec. The R-12 capacity spec is usually on a tag on the existing compressor or in the factory
When we first started doing retrofits we were told the 80% of charge rule, but as time went on they say you can use up to 100% charge level.From what my associate that was in the a/c aftermarket when the R-134a OEM use was being prototyped, the "people" originally told them it would take 20% more gas than the R-12 did, so that was what the earliest testing was done with. With poor cooling resulting. When somebody decreased the charge level to 20% less than R-12, then cooling performance returned. Which also tended to parallel what was later in the literature of converting to R-134a from R-12.
