Cruise Control Vacuum Line Size
MrMoparCHP
Lompoc, CA
In working on my car I noticed that the two vacuum lines need to be different size at each end.
The hoses I took off were 1/4" and fit one end properly. At the check valve and at the brake switch.
The other ends attach to the servo, one should be 3/8 and the other 5/16, the hoses that were on the car were stretched to fit. I find this odd.
Looking at both the parts book and the service book make no reference to this.
Does anyone have information on this, preferably and original system.
Thanks,
Alan
Thanks,
Alan
I know this is an old post, but yours was the only one I found that had raised my question I was looking for answers on.
Did you ever solve your hose issue?
What did you use?
Thanks.
Best I can tell the factory just forced the 1/4" line onto the larger fittings.
I put the end of the tubing in hot water for a minute and pushed it on.
Alan
Alan
I had to do the same, I put a drill through the hose end. I was worried it would split. Thanks.
