Remove all the screws (front and under lip) across. Then remove the plastic parts (The ones you just took screws out of, map light, corners)
These are the screws you are looking to remove by the way.
Unplug everything circled here. ( crawl under the steering wheel and remove the vent running across) For the love of creation double check to make sure you didn't forget anything. The plug circled closest to clock, the pins will break off like they are made of butter so be careful. Undo the ground part of the radio, and the two screws pointed out here, one in each front corner. Slide the radio back and down. Now go to the front, and pull slower than molasses in January. Shine a flashlight back there and make sure nothing is caught or forgotten. You should be able to flip it out from the top and unscrew the two screws to the panel, and pull it out. Cut your hole and do all of this in reverse.
I can't guarantee that you can do it.
However I can guarantee:
-Mangled hands
-Frustration
-Aches and pains
-Something WILL break
-Cursing
-Not being able to see
-When you are finally done with the struggle of putting it all back together, being happier than a possum eating sweet potatoes until you find out you forgot the one little bitty thing that is the hardest to get to.
~BEWARE~
The 8th world wonder is not breaking something in this process
