Decoded 1965 300L Fender Tag.
Torky
Brentwood California
Having trouble posting a .pdf from my drive. This looks OK. Anyone have a stripper '62 or '65, a wagon, a three-speed stick, another loaded Chrysler or Imperial?
For those wondering, this is my 300L. My New Bus!
I think the build date is wrong. Everything I've read says A=Oct, B= Nov and C=Dec.
The date for this one is Nov 25. 1964.
I can't verify the power trunk release as someone added a later electric release.
This car has the rear speaker with reverb unit too, but that may have been added.
Thank you for the response. I misread the "B" under SO as an "8" due to tired old eyes. Looks better now. The fender tag can only include factory-installed equipment. Somewhere, I picked up that code P( stands for the console and the trunk release--from the factory. Are you sayin the power trunk release looks to be strictly add-on. Earlier years trunk releases were vacuum. I'll have to do a review of the reverb presence. In previous years, the radio was coded without a rear speaker and the reverb was coded separately as including the rear speaker.. Your feedback and insights have been valuable to me. If you will send the VIN, I will rerun the report along with the date correction. Thanks, again.
The power trunk release in the car now is definitely a later, late 70's or so unit with the button not in the glove box or console.I would expect my car would have had a vacuum unit, but now I have to look into it more.
My 70 300 would have had a vacuum unit on it, if it had one. I'm certain of that.
The shop manual indicates the factory trunk release button is in the glove compartment and connects by wire to a solenoid at the trunk latch. See page 8-80 in the electrical section: http://www.jholst.net/65-service-manual/electrical.pdf Excellent source for shop and service manuals for the Chrysler letter-car years.
Mystery solved!
I did some looking in the parts manual and discovered that the Imperial had a electric trunk release and the Chrysler/Plymouth/Dodge C-bodies had a vacuum trunk release.
And 8-80 in the FSM shows AY-1 which is an Imperial.
And just to show the model callouts. AC-2 being 300 and AY-1 is Imperial
FWIW, I had a 66 Nupe with a vacuum trunk release, and a button on the bottom of the dash, left of the column, near the tripmeter reset knob.
Don't recall that I scrutinized if for originality, though.
