Delco self exciting alternator
Forward Look Forum
  1. goodneighbour
    goodneighbour Well-Known Member
    509
    254
    Nov 12, 2010
    Clinton,Ontario
    Has anyone tossed the generator and all the related bs in favor of a self exciting internalally regulated alternator? Just a thought, save bolting a voltage regulator on the firewall and all the wires that go with it.
  2. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    3,884
    964
    Mar 27, 2017
    Cornelius Or
    I guess it would depend on what type you intend to use. Most of the mounting hardware is going to be different so keep that in mind. GM made a first generation internally regulated unit in the early '70's and the were a popular choice with hot rodders of the day because they were an easy install. Problem was that the voltage regulator inside the unit was a POS. It was easily fried by jump starting the car or if there was a loose connection for a battery cable or the hot lead to the alternator. The later units were upgraded and were much better protected. That having been said, Taking apart the whole alternator to replace a dead regulator is still a PIA.
  3. goodneighbour
    509
    254
    Nov 12, 2010
    Clinton,Ontario
    I was going with a old style alternator, the same as my Oliver 770. I'm prepared for the bracket fab, using the mopar brackets as a reference for the tape measure.
  4. CBODY67
    CBODY67 Senior Member
    3,595
    796
    Mar 27, 2011
    I think the '68 Pontiacs had an internally-regulated Delco alternator? As other GM brands still had the external regulator?
    I think the Delco units are more versatile due to their different output levels for different applications. Some with smaller pulleys than others, too. Usually durable units, in general.
