Dumb I am......advice sought. Power Door Lock 65 NYer
Early C Bodies - The Slab Side Years
  1. emmd61
    emmd61 Member
    179
    102
    Dec 5, 2015
    north carolina
    174156458_456258498820929_775822950548533922_n.jpg 174334477_196566795399180_396031564417561873_n.jpg 139871836_433142301144903_5376520619067408496_n.jpg Hi All. Slowly addressing options on this 65 wagon. I got door panels and interior out. Working on power windows and power door locks. When I try to engage the power door locks there is a relay that clicks behind kick panel. Not sure it means short, or time for new relay.
  2. patrick66
    patrick66 Old Man with a Hat
    5,318
    2658
    Jul 4, 2012
    Central Oklahoma
    That is where the breaker is for the locks.
    Sweet wagon!
    • Agree Agree x 2
  3. live4theking
    live4theking Old Man with a Hat
    10,768
    2949
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    I think what he's say above is that what you are hearing is the resetting breaker popping open due to the system drawing too much current. I've never worked on these old power lock systems, but I'd guess that something is stuck. When you try to use the lock button then it draws too much current and opens.
  4. detmatt
    detmatt Old Man with a Hat FCBO Gold Member
    25,827
    11753
    Nov 14, 2010
    You could bench test the door lock solenoids individually without removing them from the doors.
    • Agree Agree x 2
  5. mr. fix it
    mr. fix it Old Man with a Hat
    7,720
    5938
    Aug 14, 2013
    Habitating in Kingston, NS
    Check out the wiring loom that hinges in the driver’s door
    I have seen this wiring fail in the past
    • Agree Agree x 1
  6. Devinism
    Devinism Member FCBO Gold Member
    80
    31
    Feb 15, 2016
    Wagoner, OK
    I would shoot WD40 on all of the linkage/pivots/tracks/rollers etc. Windows and locks. Even the door latches. You may just get them working if you keep clicking up/down/up/down. Be happy if the windows only go an inch, then 2 inches, etc. Same with the locks. Don't hold the switch or lock button in position too long. I've rebuilt many window switches with fried contacts. Just keep "bumping".
    I got quite a few MoPar windows / door locks going like this (20 years ago!). Follow up with white grease.
    It's a messy job, but somebody (else!) has to do it.
    Good luck!
