Matt Conlan
Broke off a brake bleeder flush with the mount. Try to EZ-out it out, or just replace the wheel cylinder? opinions? And thanks.
Most of the time if the bleeder screw was rusted enough to twist off, it is not likely to come out with an easy out. You can try some PB Blaster, but you will probably need to replace the wheeler cylinder.Broke off a brake bleeder flush with the mount. Try to EZ-out it out, or just replace the wheel cylinder? opinions? And thanks.
good tip! Yeah, I use eBay a lot for NOS Parts. I work on 60's-70's Internationals, too. Cant quite bear to put a made in China part on these machines.Most of the new brake cylinders you'll buy over the counter are off shore manufactured and questionable quality. I've been there and done that.
I like finding NORS good quality brake cylinders and replacing the rubber seals if needed. eBay is a good source or @mobileparts can probably get you NOS or NORS parts too.
